Re: 806 IHC
Posted by chadd on September 26, 2006 at 12:14:51 from (155.92.30.100):
In Reply to: 806 IHC posted by Elvin on September 26, 2006 at 11:06:57:
More than likely the same thing that is wrong with ours. The MCV pump is probably starting to get bad and so when several things are trying to be used at once, it runs out of pressure and something gives. It will usually happen when the steering is turned to its lock and also when you press one brake all the way down. We don't have the time or the finances right now to fix it, so we just make sure not to turn super short. Otherwise it involves pulling the entire MCV (the plate right in front of the stair to get on the tractor) out and replacing the pump mounted on the back. It might also be a valve though too. The only way to know for sure is to flow test it, which most people (me included) don't have the tool to perform.
