Re: Fuse in a 47 Farmall H
Posted by John T on September 27, 2006 at 19:07:45 from (66.244.90.5):
In Reply to: Fuse in a 47 Farmall H posted by Wallsy on September 27, 2006 at 18:52:11:
The fuze size n rating is more of its physical mounting dimension and its current rating then whether or not its used on a 6 or 12 volt system. Its voltage withstand rating is wayyyyyyyyy higher then 6 or 12 volts anyway, so if the fuze fits into the socket and is the proper current rating (say maybe 10 to 15 amps in a tractor lighting circuit) THEN IT WILL WORK REGARDLESS IF THE TRACTOR IS 6 OR 12 VOLTS.......
Thats kinda the same story about ignition points n condensor, they are passive current switching devices and their current rating is whats critical and again, their voltage withstand rating is wayyyyyyyy higher then 6 or 12 anyway.
Sooooooo Nooooooooo I dont envision any special fuzes for tractor use for 6 or 12 volt ONLY, its the size and current rating that counts and when you buy one for general auto or truck or tractor use I dont expect anyone is gonna ask or care if the tractor is 6 or 12 volts, they just need to know its size and current rating.
John T
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
