Re: 656 again. Houston we have a problem, and more
Posted by chadd on September 28, 2006 at 10:30:13 from (155.92.30.100):
In Reply to: 656 again. Houston we have a problem, and more ??? posted by Harold Hubbard on September 28, 2006 at 09:50:13:
Harold, I am not positive (someone please correct me if I am wrong) but I think that clutch pedal is a direct mechanical linkage to the clutch. If it took no effort to push the pedal, check the clutch spring. If it is broken, it would go really easy. More than likely though, the clutch pressure plate and the friction disc are stuck, rusted tight, or maladjusted and that is why you are unable to shift. The steering wheel should not freewheel with the engine off (at least our Hydro's never did). That means either the check valve in the line is stuck allowing the fluid to bleed back into the rear end or the filter is plugged and the filter bypass valve kicked in. When that valve opens up it makes noise. Just a few ideas Our Hydro was pretty different from the gear drive model though, so check with someone who had an actual gear drive model just to confirm.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
