Re: FIRING ORDER
Posted by Wardner on September 28, 2006 at 17:04:40 from (4.154.245.114):
In Reply to: Re: FIRING ORDER posted by El Toro on September 28, 2006 at 07:38:23:
Two and three can never be consecutive. The same applies to one and four. I say "never" because it would add alot to the manufacturing costs of the crankshaft. It would also require five main bearings. Five main bearing cranks are the norm now but this wasn't the case a few years ago. Engines are now made to crank out more HP per cubic inch.
I am not really qualified to comment on this but I think there are harmonic balancing considerations when deviating from traditional firing orders. It would be interesting to look up the firing orders of engines that use gear driven balancers such as the Ford 172 cubic inch diesels.
