Re: FARMALL 100 TRANSMISSION BEARING NOISE
Posted by NICK D on September 29, 2006 at 03:51:49 from (71.31.65.122):
In Reply to: Re: FARMALL 100 TRANSMISSION BEARING NOISE posted by Roger46 on September 28, 2006 at 17:16:45:
You may be right about that because I don't remember the noise before I installed the right angle PTO assembly for the mower. However, the noise sure seemed to be coming from forward of the pto, under the gear shift area. I will remove the PTO assembly and see if it persists.
Thanks for your reply
