Re: B275 - hard starter
Posted by Michael Soldan on September 29, 2006 at 06:15:34 from (24.235.41.226):
In Reply to: B275 - hard starter posted by ennismore.mike on September 29, 2006 at 04:19:02:
Ennismore Mike, I have a story for you, I've told it before on this line. I bought a B250 that sat for 8 years..was impossible to start without ether and ether is bad news. I suspected that the tractor had been abused a bit and when I changed all fluids and filters I was right. I also suspected dirty injectors slobbering fuel into the cylinder instead of misting it in. Long story/short I bought diesel fuel conditioner which cleans injectors, removes moisture and lubes the pump. I installed a new battery and kept it fully charged. I used the glow plugs and usually held it on for at least 30 seconds, after a few tankfuls of fuel treated with the fuel conditioner , the tractor started easier and easier. Then a friend who had been an AC dealer for 40 years told me to put a quart of automatic transmission fluid in with the tank of fuel as it is good to remove moisture and lube the pump. I have continued to put conditioner in the tractor and the occasional quart of oil or trans fluid in with a fill. I can start this tractor on the coldest day of the winter. I firmly believe that my injectors were as dirty as could be and this product cleaned them and assisted in making an easier start. I sometimes put a trickle charge on the battery in cold weather just to insure it is fully charged. I sometimes use the tractor for short durations and so the extra charge just ensures a better start. I also removed the oil pan after I got it and found an inch and a half of black cheesy sludge in the bottom of the pan, thius cleaned up gave me better more consistent oil pressure as the pick up would draw sludge sometimes. Interestingly as in your case my tractor ran fine once it warmed up,even slobbered fuel will ignite fine when the tractor was hot, yet it creates a poor start up condition. It is worth trying some injector cleaner for diesel rather than tearing the tractor apart. You may eventually need to look at the injectors and you may have to replace them(worst case senerio), on the other hand you may luck out like I did and a few tanks of treated fuel will clean things up. Definitely add a quart of trans fluid to lube your pump and get all moisture out of the system. Add a quart of oil to the fuel once in a while too and keep the pump lubed. If you have a good battery that spins the engine quickly it will be an asset. I have seen tractors not start and they seem to be turning over ok but when new batteries are added the tractor turns over much quicker and starts easier. My suggestion will cost you no more than $15 and its worth a try and it worked for me and I couldn't be happier with the way the B250 starts...Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
