Re: B275 - hard starter
Posted by tasbrus on September 29, 2006 at 06:30:20 from (24.59.31.200):
In Reply to: B275 - hard starter posted by ennismore.mike on September 29, 2006 at 04:19:02:
Also check the voltage from the ends of the glow plugs to ground. #4 should be something like 4-6 volts and as you go twards the front they will each drop a little in voltage. If you get a big drop like to less then 1 volt you have a shorted glow plug or wire.
