Farmall Tractors Discussion Board
Re: 330 utility running wide open
Posted by The Red on January 28, 2000 at 02:04:11 from (12.75.196.25):
In Reply to: 330 utility running wide open posted by Buzz on January 28, 2000 at 00:28:35:
Might want to pull the cover off the governor housing. Sounds like a broken spring or the thrust bearing assembly is worn. At least that is what I would suspect on one of my Hs.
Post A Followup
: Re: Re: 330 utility running wide open
