Re: Galaxy Tires? and Super A Tire size?
Posted by K-Mo on September 29, 2006 at 15:25:15 from (65.169.189.2):
In Reply to: Galaxy Tires? and Super A Tire size? posted by tractorsam on September 29, 2006 at 12:39:02:
Measure inside the rim where the bead seats. If you are measuring 9" to the outside, then you probably have an 8" rim. The specified size for an 8" rim is a 9.5 and 10" rim is 11.2. It's very common however to find an 11.2 on an 8" rim.
K-Mo
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
