Re: Oil for hydraulic for H
Posted by RustyFarmall on October 04, 2006 at 14:07:30 from (199.120.81.246):
In Reply to: Oil for hydraulic for H posted by Farmer Ryan From WI on October 04, 2006 at 12:31:08:
The manual calls for non-detergent motor oil, 30wt for summer use, 20wt for cooler weather, and 10wt for extreme cold. Actually, that hydraulic system really doesn't care. Lots of folks are using IH Hy-Tran or the equivalant.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
