Farmall A transmission front oil seal
Posted by Sott Griffith on October 04, 2006 at 18:23:32 from (66.23.231.146):
I'm curious if anyone has tried and been succesfull in changing out the front oil seal on the input shaft of the transmission through the hand hole in the bottom of the tractor. Is it possible or will I have to split the tractor? I'm wondering if I can remove the shaft bolts and slide it out of the way far enough to remove the seal housing and replace the seal or have I gone off the deep end?
Thanks,
Scott
