Farmall H probelms?
Posted by dej(JED) on October 05, 2006 at 05:37:02 from (66.212.151.134):
I just got a 52 H. I flushed the tank, which really wasn't bad. Installed new plugs, wires, cap and rotor. It starts up only if you hold your hand over the carb intake side. It will then run for a couple of secs.and then die out.It is getting good fuel flow from teh tank. I am thinking the carb is gummed up. The manifold isn't sucking air anywhere?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
