Re: Help identifying voltage regulator poles
Posted by Bob M on October 06, 2006 at 06:37:58 from (151.190.254.108):
In Reply to: Help identifying voltage regulator poles posted by Matt Williams on October 05, 2006 at 19:59:41:
Hey Matt - If you have an ohmmeter you can use it to figure out which regulator terminal is which. Set the ohmmeter to it’s lowest range (ohms x 1). Connect one test lead – doesn’t matter which - to the regulator base. Then test each regulator terminal with the other test lead. Results should be as follows: F (or FLD) – ~0 ohms G (or GEN) – several ohms B (or BAT) - open circuit (infinity) Obviously the remaining terminal will be the L. --- Additional tests: 1 - Remove the regulator cover. You should find two relays inside. 2 - Attach one test lead to the regulator base and connect the other to the F terminal. Now push the voltage regulator relay armature down (the voltage regulator is the relay whose contacts are held SHUT by spring pressure). The meter should read several tenths of an ohm with the contacts held manually open. 4 - Connect one test lead to G terminal and the other to the B terminal. The ohmmeter should indicate open circuit. Now manually push the cutout relay down (the cutout's the the relay whose contacts are held OPEN by spring pressure). The meter should read ~0 ohms with the cutout contacts held manually closed. --- Note: It's possible your regulator has only 3 terminals (ie. the L is missing). If so simply connect the ”orphaned” wiring harness L wire to the B (or BAT) terminal on the regulator. Hope this helps...
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
