Re: Farmall H - rototiller
Posted by Nat 2 on October 06, 2006 at 07:44:02 from (64.80.110.27):
In Reply to: Farmall H - rototiller posted by Trent M on October 05, 2006 at 22:03:11:
The only way to get a gear low enough for a rototiller on a stock H would be to drive the transmission with a hydraulic motor by way of the belt pulley.
Problem with that is, you need to keep the clutch pedal pushed in for it to work (transmission has to be in gear), which disengages the PTO and belly pump so you can't run the hydraulic motor or the rototiller...
I guess an H won't work very well unless you buy a rototiller with its own engine. Then you could rig up the hydraulic motor-driving-belt pulley creeper.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
