Re: Farmall F-12 trip bucket loader?!?!?!?
Posted by Don Hopf on October 06, 2006 at 09:30:35 from (216.16.41.33):
In Reply to: Farmall F-12 trip bucket loader?!?!?!? posted by Efcattle on October 05, 2006 at 11:56:16:
Is there a winch and a belt pulley at front of the loader. Seen one of these at the local old tractor gathering that used the tractor pulley running a belt to the front of the tractor.
At the front of the tractor, the belt driven pulley turn a small steel wheel. Above this was a larger steel wheel that was connected to a cable drum by a steel link chain. The large steel pulley moved up and down about 2 in. There was a spring that held the large wheel up against a brake pad the stop it from turn. By pulling a lever alittle, the large steel wheel would move down away from the brake pad and the loader would drop. Pulling the lever all the way would bring the large wheel down against the belt driven wheel and raised the loader.
Think about using this loader for liftint a motor out of a vehicle!
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
