Re: 684 front end loader hydralic problems
Posted by Stephen L Johnson on October 06, 2006 at 17:01:00 from (12.107.247.86):
In Reply to: Re: 684 front end loader hydralic problems posted by Janicholson on October 04, 2006 at 18:23:28:
Thur winter tractor is used to take out round bales, and at least once a week rest of year-bushogging, mowing and baling. No special conditions when it quits, but bucket is always on ground when it quits, and won"t lift back up. Don"t let it just sit, I drag it backwards on ground, tap on the valves with a piece of brass, and in about an hour or two will usually lift back up. Tractor has been setting several days this time and I broke several hyd.lines going to the loader, and there was no hydralic fluid under pressure in the lines. The hydralic oil and filter was changed this spring. Thanks for replying.
