Re: Starting Problems with my H
Posted by Dave in CT on October 07, 2006 at 18:00:58 from (69.182.78.191):
In Reply to: Starting Problems with my H posted by Dave in CT on September 30, 2006 at 19:08:44:
Posted the solution in a new post but I want to archive the answer here - it turned out to be the battery cables. I put in some fat new ones and ran the negative cable to ground on a shiney spot on the starter flange. Starts fine now.
This confirms that it was a bad cable - everything else was either rewired or rebuilt - new starter solenoid too. Most likely it was that thin positive cable but I replace both to be safe.
This is also to document that I went from starting fine to an absolute no-start situation just with resistance building up in the cable. I checked connections before I started monkeying with stuff and nothing had changed - the connections were all tight. I did have the starter rebuilt - it was done by a guy who'd given me a lot of free advice and I was planning to have it done anyway. I know the starter was not the culprit because when I put it back in I still had the same problem.
