Re: Farmall H - rototiller
Posted by Delta Dirt on October 07, 2006 at 19:10:37 from (64.49.3.65):
In Reply to: Farmall H - rototiller posted by Trent M on October 05, 2006 at 22:03:11:
I have had a lot of experience with roto tillers---back in the 60"s & early 70"s, I worked for Howard Rotavator as a factory rep. Have used them on the farm and still occasionally use one.
For most applications---the H, M & 460---560 (5 speed transmission) tractors had to fast of forward speeds to really do an adequate job. One thing for certain----you need a direct drive gear train that will provide a "braking force" against forward thrust from the tiller. The early TA"s would increase pulling power, but allow "free wheeling" against the forward thrust of the tiller (as if disengaging the clutch).
Depending on how serious your tiller plans are--I would highly recommend finding a tractor with a little more HP, 8 speed transmission (with several low forward speeds), live PTO and live hydraulics. Its not that it can"t be done with the H---just that you would probably be better satisfied in the end. I have run an 80" cut Rotavator on one of my M"s---but never was real pleased. Also have run an 80" on my Kubota L2850 (28 hp), but with extremely low speeds and operating the Rotavator very shallow.
One thing to keep in mind----don"t know about other brands, but most of the Howard machines have a multi speed gear box, where you can change the blade speed in the rear of the gearbox. The slower you turn the blades---the less power is required from the tractor. At the same time---in order to take a smaller bite with the tiller blade (and result in a finer textured seed bed), if the blades are turning slower---you need a slower forward speed on the tractor. Conversely----with more power, you can speed the blades up, move the tractor faster and do more work.
A good rule of thumb is 1 HP for each 1" of cutting width of the tiller. For lesser HP ratios---you really need slower forward speeds.
Good luck on your project----keep us posted.
Delta Dirt
Avon, Ms 38723
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
