Well thats 2 out of 3 running now but I have a ?
Posted by old on October 08, 2006 at 12:57:47 from (4.244.186.165):
Well I got the 340 and the M both to run well. Now for the question. The book says you have to remove the radiator to remove the water pump, but do you really have to remove the radaitor or can the water pump be pulled off with out doing so??
Thanks.
If it wheren't for the water pump being locked up I would have taken it for a test drive
