Re: # grease zerks on 300 u
Posted by JayWalt on October 08, 2006 at 17:16:07 from (24.223.138.48):
In Reply to: # grease zerks on 300 u posted by Jimer on October 08, 2006 at 09:34:22:
the clutch throwout bearing is on the right side just in front of the brake pedals, its just a zerk on the casting. As soon as I pumped grease in there it came out around where the zerk was installed, I dont know if this is normal...
Here is a list...
1. Water pump bearing and shaft (2)
2. Brake Pedal
3. Rear axle bearings (2)
4. Steering knuckle pivot (Spindles) (4)
5. Drag Link F and R (Tie rods) (4)
Clutch Throw Out bearing (1)
FASTHITCH
6. RockShaft mounting bracket (2)
7. Rockshaft Actuating Bellcrank (3)
8. Leveling Screw Swivels (upper and loweer)(2)
9. Leveling Screw Gear Housing (1)
10. Lateral Link Extension (2)
11. Lateral Link (1)
12. Generator oil cups (8 to 10 drops of SAE 20w)(2)
13. Starter (a few drops of SAE 20w)(1)
14. Distributor (remove plug and oput in grease zerk, pump til grease comes out the opposite side hole)
15. Oil the rotor felt, under the distributor cap
16. Repack Front Wheel bearings
Then all your fluids, like rear end, engine oil, hydraulic oil and so on.
If you have a TA and/or magento, there is a few more/different spots...
Good ideas to get a manul, only cost me $17 from CASE IH
