Re: M FARMALL PISTONS
Posted by El Toro on October 09, 2006 at 07:19:50 from (205.188.116.133):
In Reply to: M FARMALL PISTONS posted by bm3501466 on October 09, 2006 at 06:44:00:
You can get a sleeve and piston set for high altitude from weberstractorworks.com. These are the 4.00 inch pistons. They may be able to tell
you who they were made by.
For your cylinder head I would call a reputable
auto machine shop and see what they charge for the head. Hal
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
