Re: Fair price for a C113 engine (farmall a,b,c)
Posted by El Toro on October 09, 2006 at 07:30:01 from (205.188.116.133):
In Reply to: Fair price for a C113 engine (farmall a,b,c) posted by bshannon on October 09, 2006 at 07:06:04:
I would agree with Bob on rebuilding your engine.
Soak those pistons with ATF and then see if they can be driven out using a piece oak and a hammer.
Those are wet sleeves and are not pressed into block. When you start tapping on the connecting
rods the sleeve and piston may come out together.
If all this fails your local auto machine shop can remove them. With a new sleeve and piston kit, crankshaft polished or ground, new bearings
and the cylinder head reworked your engine will
last a long time. Hal
