Charging battery on a postive ground system ??
Posted by Oldman1151 on October 09, 2006 at 16:56:53 from (66.82.9.86):
I have a 1942 Farmall BN with a 6 volt positive ground system. I charged the battery once but I unhooked the battery cables because I was unsure of the postive ground issue. The tractor has been repainted and it is not easy to take the cover off of the battery box and I do not want scratch it up taking the cover on and off. To avoid this can I hook the positive lead from the charger to ground on the tractor and the negative lead from the charger directly to the starter. Seems like it should work. Will this work?
