Re: 444 Hydraulics
Posted by IH2444 on October 09, 2006 at 19:00:09 from (209.209.136.159):
In Reply to: 444 Hydraulics posted by Flying 444 on October 09, 2006 at 17:18:41:
Does your tractor have remote hydraulic hookups ? If not do not close the isolation valve. Is your other lift lever pushed all the way forward ? darn I forget the name of it right now, it is beside the lift lever...darn brain glitch need to go to bed. The lift raising on it's own would to me indicate a problem in the lift box mechanism. On the level If you check in the top of the lift box fill plug I think it is supposed to be 4 inches down from the top of the opening.
Mine has an auxilliary pump on the front and the level check is totally different.
But I don't think fluid level is your problem.
Ben
