Re: Thanks to Janicholson on recent 340 Utility ?
Posted by JayWalt on October 10, 2006 at 06:18:34 from (24.223.138.48):
In Reply to: Thanks to Janicholson on recent 340 Utility ? posted by T. Allen on October 09, 2006 at 18:54:00:
He is a very knowledgeable and valuable asset to the board for sure. He's helped me a few times and has never given me an attitude when I've had abnormal posts/questions =)
Thanks I swapped the whole assemblies, the valve, reg, check valve are all in the front now and the single valve is in the back spot.
What is the point of the check vavle?
Why is there a regulator on the hitch cylinder and not one on the lift rams?
Thanks Janicholson!
