Re: Troubleshooting H charging system
Posted by Red Dave on October 10, 2006 at 07:46:35 from (66.216.141.163):
In Reply to: Troubleshooting H charging system posted by Greg Eichler on October 10, 2006 at 05:54:11:
I'll give you a little shorter answer.
Put the probes right across the battery. Battery voltage should be about 6.4 or so on a fully charged battery. It should increase to 7 volts and more when charging.
With the engine running about half speed. place a jumper from the "field" terminal of the generator to ground. If it starts charging, the trouble is likely in the regulator, if it doesn't, the trouble is likely in the generator.
Make sure the regulator is solidly grounded before you go buy one. Make sure your generator is polarized (flash the field) before you tear it off to work on it.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
