Re: Darned Old Tractor!
Posted by Janicholson on October 10, 2006 at 12:23:59 from (199.17.6.122):
In Reply to: Darned Old Tractor! posted by Allan In NE on October 10, 2006 at 01:39:13:
Dear Allen,
The only thing I can add to the sage advice below is that it is likely that air gets trapped in the core/lines at their highest point. Sometimes it is gasses that are driven out of the coolant. This "vaporlock" is hard to remove. I like to put a pressure tester on the rad. then loosen the highest point on the hose to core connection, allowing the air to escape. The best is to have a vent soldered into the core at its highest point that can be opened easily with a little valve. Then when the unit is up to temp, venting uses the internal system pressure to push out the air. I hope I helped some. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
