Farmall Tractors Discussion Board
Re: Farmall B Crankshaft Pulley
Posted by Jim Becker on January 28, 2000 at 16:02:35 from (209.30.79.243):
In Reply to: Farmall B Crankshaft Pulley posted by David Bilyeu on January 28, 2000 at 13:03:28:
The crank is threaded for pulling the pulley on when installing it. Once installed, it is simply held in place by being a press fit. However, some very early Bs had a pulley with a set screw on the side. If drilled for it, one should be installed.
Post A Followup
: Re: Re: Farmall B Crankshaft Pulley
