Re: Orings on a IH 300u
Posted by Janicholson on October 10, 2006 at 18:19:22 from (66.173.50.109):
In Reply to: Re: Orings on a IH 300u posted by JayWalt on October 10, 2006 at 02:26:35:
I believe that the best o rings are teflon based rings, pricy, but pretty much for ever. Standard rings are made from (usually) buna-N, which is a synthetic oil resistant rubber like material. They are OK but do take a set. Sink "O"rings are rubber/neoprene and often melt or turn to expanded jelly in petroleum based oils. The check valve in the hitch cylinder line is (I believe) to prevent catistrophic sudden lowering of the implement/hitch. Which would not be reasonable to put in a valve system hooked up by the user for other purposes. My best info, JimN
