Re: Threads in cast wore out
Posted by John T on October 10, 2006 at 20:46:54 from (66.244.90.5):
In Reply to: Threads in cast wore out posted by Jimer on October 10, 2006 at 20:37:00:
One alternative to drilling n tapping is heli coils, but you still gotta have the corect oversized hole in the first place to insert the coil so not sure if thats any better in your situation???????? i.e. if you gotta drill anyway go ahead n drill n tap ???
I bought a set of titanium drill bits and those with lots of oil during drilling helps some. If you get the correct pilot hole and use the good instead of cheap soft tap real slowwwww and oiled and in n out in n out you may eventually get r done........
John T
