Re: 826- Power Steering Buzz
Posted by the tractor vet on October 11, 2006 at 06:54:58 from (75.24.42.197):
In Reply to: 826- Power Steering Buzz posted by Jim Allen on October 11, 2006 at 05:50:58:
This could be caused by the flowdivider in the MCV or even the pressure reg. or air getting into the sysetm . Also you are past due for a fluid change . With out putting the gauges to it to see just what it is doing i am not even going to try and figure it out . It is like this don't worry about it and run her till she stops working then we will diecet it .
