Re: no spark on h
Posted by Farmall_Ryan on October 11, 2006 at 09:05:48 from (69.202.135.234):
In Reply to: no spark on h posted by hobee on October 11, 2006 at 08:35:14:
I would try a couple quick checks before getting inside the mag. Since you say its a mag ignition, you should have a ground out switch that is connected by a wire to the side of the magneto by a small nut. Take this nut off and remove the wire from the mag. Now you know for sure that the mag isnt grounded by a bad wire or faulty switch. Now pull the primamry wire off from the center of the distributor cap (the one coming from the magneto cap) and hold it about 1/4 inch from the side of the grounded engine block. Try turning the tractor over now (you may need a helper to hit the starter button). If you have spark you know that the magneto is ok inside and the issue is either with the kill switch circuit or somewhere from the dist cap to the plugs... If you dont have a spark, you will have to open up the mag to check some things. Bewteen the link Bob gave you, and help from people on here, we can walk you thru it. MagMan rebuilds H4 mags if you need to go that route as well...
Home
| Forums
Today's Featured Article -
Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
