Re: 2-POINT HITCH PLOW FOR 460
Posted by Allan In NE on October 12, 2006 at 10:29:14 from (148.78.243.25):
In Reply to: 2-POINT HITCH PLOW FOR 460 posted by NORTHERN FARMALL on October 12, 2006 at 09:41:38:
NF,
Yes, there are two pins in the lower arms. Pull those pins out so that there is no down pressure on the plow. The hitch should "flex" or bend in the middle. Also, you've got to drop the lift collars down to the second notch so that the land side doesn't hold the furrow side out of the ground.
Now, after all that, if the plow won't go in the ground it has something to do with the plow, not the tractor, as that plow needs to "suck".
Has it got good points and lathes?
Allan
