Re: Wd6 carb.
Posted by Geoff NY on October 12, 2006 at 13:16:09 from (24.185.230.57):
In Reply to: Wd6 carb. posted by tyler cohrs on October 11, 2006 at 18:58:55:
The reason for needing a lot of choke most often is an air leak. Check the manifold gaskets. When you have it running spray a little WD or similar product around where the gaskets are. You"ll know if they"re leaking the engine will pick up.
