Re: M fouling plugs
Posted by Wes in Ohio on October 12, 2006 at 21:36:29 from (12.4.26.248):
In Reply to: M fouling plugs posted by chadd on October 12, 2006 at 07:27:20:
Had a similar problem about a month ago on my 300 U, tried hotter plugs and that just made it run alittle longer, discovered that the advancing spring in the distributar were so weak it was running at full advance in idle, used alot of fuel also, check your timing to see if your engine advances with your thottle, if it doesn't check your springs
wes
