Farmall Tractors Discussion Board
Re: 3 point for M
Posted by Marshall on January 28, 2000 at 19:20:26 from (208.199.21.31):
In Reply to: 3 point for M posted by Rod A. on January 27, 2000 at 22:25:55:
I bought the Saginaw 3 pt hitch. I'm very happy with it. Woeks just fine and fit with no problems on my H.
Post A Followup
: Re: Re: 3 point for M
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
