Re: no spark on h
Posted by Wayno on October 15, 2006 at 18:32:15 from (64.33.195.120):
In Reply to: no spark on h posted by hobee on October 11, 2006 at 08:35:14:
I had the same problem after I replaced the points on my "A". Figured I goofed on two things. 1. Put to much grease on the shaft which splashed onto the points. 2. I pushed the little block that the point spring connects to all the way home instead of letting the outer cap push it in while tightening it. The block needs to be clean and make good contact with the out cap which is held on by three screws. Worked for me??
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
