Re: A front crank seal
Posted by Will Sick on October 15, 2006 at 19:05:53 from (207.177.34.174):
In Reply to: A front crank seal posted by wayno on October 15, 2006 at 18:41:04:
Once you have the front end and the pulley off you remove the pressed steel cover that holds the seal and push out the old seal and put in the new one put the pulley back on before you tighten the bolts on the pressed steel front cover. That way the seal will be centered on the pulley and last longer.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
