Re: A front crank seal
Posted by EZ on October 15, 2006 at 20:15:22 from (209.105.203.10):
In Reply to: A front crank seal posted by wayno on October 15, 2006 at 18:41:04:
If not mistaken, you will have to remove the governor as well as the front cover. The seal has to pressed in from the inside surface. For sure look into putting in a speedy sleeve and a slightly oversize seal. It should come as a set.
