Re: Help Again?
Posted by RR Mech on October 15, 2006 at 20:57:04 from (12.154.7.21):
In Reply to: Help Again? posted by Allan In NE on October 15, 2006 at 08:37:56:
If its a 2 prong switch make sure the ground side of the switch is grounded. If its the one wire switch make sure the sender itself is to a good ground. If that checks out then you just need a new switch.
