Re: adding water to battery
Posted by Janicholson on October 16, 2006 at 10:26:45 from (199.17.6.122):
In Reply to: Re: adding water to battery posted by RustyFarmall on October 16, 2006 at 08:06:17:
My well in MT had 3700ppm disolved solids That is an issue. If you can taste the water it is probably best to use distilled. JimN
