Re: C charging problems
Posted by Janicholson on October 16, 2006 at 12:57:33 from (199.17.6.122):
In Reply to: C charging problems posted by Tim Mattson on October 16, 2006 at 12:10:19:
John T has great charging system analysis info on many posts in the archives (No need to reproduce it) I would start by making sure that the connections to the original light switch L-H connection is not being used. I would then make sure the regulator was grounded well to bare metal, or seperate ground using 10 gauge wire, and good terminals. Next I would ful field the gen by starting the tractor and grounding the field terminal with a aligator tipped jumper. If the gauge then shows greater charge, 15-18 amps, I would adjust the voltage regulator (because I know how, or read in a good manual on the delco system you have), or replace it. The voltage should be between 6.7 and 7 volts at high idle. See johns material for more if needed. JimN
