Re: 560 intermittent hydraulics
Posted by LumbrJakMan on October 16, 2006 at 15:32:40 from (64.12.116.65):
In Reply to: 560 intermittent hydraulics posted by JW in WI on October 16, 2006 at 13:25:36:
JW I had a similar problem with my 560. I found the filter and flud change worked at first . The it started to slow and eventually stopped . I found it was getting water in the system and the reason it stopped is it was watering the fluid down and actually freezing it. Then it would not work. I shedded my 560 and did another fluid change and that fixed it.
Is it getting down to freezing where you are ?
