Re: 560 intermittent hydraulics
Posted by the tractor vet on October 16, 2006 at 16:18:06 from (75.24.38.242):
In Reply to: 560 intermittent hydraulics posted by JW in WI on October 16, 2006 at 13:25:36:
Well if it is not like the other guy said and it is not freezen up yet then i would be looken at the pressure reg. or a sticking flow divider . But i would realy run a flow test on the pumps . I know that you don't have the stuff to do this with but ya can get yourself a hyd pressure gauges that will read atleast 300lbs. and plug that into one of your remotes and see what she has for pressure . or take it into a I H dealer and have them run a flow test and pressure test on it that way you will know forsure that it is not the pump going bad.
