Re: Farmall B, 3pt?
Posted by gene bender on October 16, 2006 at 18:33:33 from (67.55.226.214):
In Reply to: Farmall B, 3pt? posted by fennsz on October 16, 2006 at 18:21:48:
Hard to do because the B doesent have hydraulics but i have seen some that were built by adding a pump and then making a three pt. Ground speed is too fast for a tiller. Get a bush hog with wheels and then you can set your depth. You would want a 5ft model depends on how high and dense the groth you are cutting. But the B is not a good choice for what you want and I am a big B fan. It can be done though by adding a gear box in the tube in front of the tranny to slow down the ground speed.
