Re: Brazing a radiator on an M
Posted by Wardner on October 16, 2006 at 18:35:20 from (4.154.242.215):
In Reply to: Brazing a radiator on an M posted by Charlie M on October 16, 2006 at 18:11:38:
I don't know how you braze brass without making a large hole. It should be soldered. Get a peice of brass sheet metal that covers the split by 1/4" all around. Clean and solder everything in the repair area. You need to be careful that you don't un-solder nearby joints. Give the job to a radiator shop if you don't feel qualified.
