Re: Cutting a flywheel
Posted by the tractor vet on October 16, 2006 at 19:41:02 from (75.24.38.242):
In Reply to: Cutting a flywheel posted by Gauger on October 16, 2006 at 19:21:28:
There is a a set hight that the step should be cut to and at this moment i can not give it to you as the wife just took all of my books and put them upstairs as tomarrow the office is getting tore up for a remodel maybe one of the other guys might have them but since you took off the pressure plate and also removed whatever amount from the face of the flywheel everything has changed . This may not have been a wise move on your part as it will affect the pressure that the plate can apply . One other thing is that when refacing a flywheel it should be ground not turned on a lathe .
