Re: Farmall H engine question
Posted by City-Boy McCoy on October 17, 2006 at 03:38:14 from (68.221.167.51):
In Reply to: Farmall H engine question posted by DJL on October 16, 2006 at 22:07:22:
Vern is correct. Black smoke is an indication your engine is running too rich. Either adjust your carb settings, or rebuild carb paying particular attention to float level setting. Your oil pressure problem is not related to the piston rings. Bad rings would make blue smoke. Rings control oil consumption - not oil pressure. Low oil pressure is normally the result of loose clearances in rod, cam or main bearings. Low oil pressure can also be caused by a weak or worn oil pump - which is where I would start first - the oil pump. Pay particular attention to the cover on the pump as they can warp or work loose and cause a loss of pressure. If you still have an oil pressure problem after checking/repairing/replacing the oil pump, then it is probably time to tear into the engine. Some of the H owners can tell you for sure, but there may also be some kind of oil pressure relief valve and passage in an H block, which may be either assembled improperly or which has failed in some way. mike
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
