Re: Farmall H engine question
Posted by Bob M on October 17, 2006 at 06:07:34 from (151.190.254.108):
In Reply to: Farmall H engine question posted by DJL on October 16, 2006 at 22:07:22:
Observations by others below are right on! Black in the exhaust means the carb mixture is too rich. Before you adjust the carb however check to be sure there’s no restriction in the air cleaner (run it with the air inlet tube temporarily disconnected). Also that the choke plate is open all the way when the choke rod is pushed in. Then try turning the high speed screw in (clockwise) ¼ turn at a time until the black just disappears and the engine still picks up without stumbling when you snap open the throttle. Only if the high speed screw bottoms out and it still smokes black will you need to go inside the carb to look float settings, etc. ---- Regarding the low oil pressure situation, first thing I’d do is switch to multi-grade oil (10W30 or 15W40). Multi-grade will make a significant difference in oil pressure when the engine is warm – especially if the straight 30 oil currently in the engine is diluted with gas from the carb running rich (which it probably is by now….) Other possible causes are a worn, warped or loose oil pump cover, or worn main/rod/cam bearings as others note. However as long as ANY oil pressure shows on the gage at warm idle and oil pressure rises when RPM’s are increased, the engine will enjoy a long life just the way it is.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
