Re: Cutting a flywheel
Posted by Wardner on October 17, 2006 at 09:18:37 from (4.154.243.22):
In Reply to: Re: Cutting a flywheel posted by Gauger on October 17, 2006 at 05:17:56:
I am not sure but I think a Blanchard grinder can only be used on a flat flywheel. As I recall, the Blanchard is a large abrasive wheel that rotates horizontally above the flywheel that is on a carriage which moves back and forth like a Bridgeport table. It will take alot of passes before it cleans off the irregular surface hardening of a flywheel. Moreover, how do you tell when the hard spots are gone? The net effect is a flywheel that only grabs the high (hard) spots after break-in.
But whatever floats your boat is fine with me.
